Parent State Names
jdtoellner
Parent State Names
Post by jdtoellner »
In the other forum you provided the following code snippet that set probabilities (weights) for a Noisy Max node.
// NoisyMaxDemo.cpp : Defines the entry point for the console application.
#include "stdafx.h"
#include "smile.h"
int main()
	DSL_network net;
	int ret = net.ReadFile("noisymax.xdsl");
	if (DSL_OKAY != ret)
		printf("Can't load input file %sn", "noisyadder.xdsl");
		return ret;
	int h = net.FindNode("A");
	if (h < 0)
		printf("Node %s not founnd", "A");
		return h;
	DSL_nodeDefinition *def = net.GetNode(h)->Definition();
	if (def->GetType() != DSL_NOISY_MAX)
		printf("Node %s is not a noisy addern", "A");
		return DSL_WRONG_NODE_TYPE;
	DSL_noisyMAX *adder = static_cast <DSL_noisyMAX *> (def);
	printf("Displaying noisyAdder weights for %s\n", "A");
	DSL_Dmatrix &weights = adder->GetCiWeights();
	for (int i = 0; i < weights.GetSize(); i++)
		printf("%d: %f\n", i, weights[i]);
	int parentCount = adder->GetNumberOfParents();
	int outcomeCount = adder->GetNumberOfOutcomes();
	for (int i = 0; i < parentCount; i++)
		int base = i * outcomeCount * 2;
		double p = (i + 1) * 0.1;
		weights[base] = p;
		for (int j = 1; j < outcomeCount; j++)
			weights[base + j] = (1 - p) / (outcomeCount - 1);
	return net.WriteFile("noisymax-modified.xdsl");
This code snippet provides me with the Noisy Max state names:
			DSL_nodeDefinition *def = theNet.GetNode(nodeHandle)->Definition();
				const DSL_Dmatrix &cpt = *def->GetMatrix();
			const DSL_idArray &outcomes = *def->GetOutcomesNames();
			const int numberOfOutcomes = def->GetNumberOfOutcomes();
I'd like to set weights based on Parent State names and the Noisy Max node state names.
What's the best way to determine Parent states?
Also, what's the best way to determine Parent names?
Are those in the Noisy Max node or do I need to traverse the parents?
jdtoellner
Re: Parent State Names
I think I've figured this out.
Get the parents with this code.
			DSL_intArray parentHandles = theNet.GetParents(nodeHandle);
			int numberOfParents = theNet.NumParents(nodeHandle);
Then get the states with this code.
			for (int parentIdx = 0; parentIdx < numberOfParents; parentIdx++) {
				DSL_node *parentNode = theNet.GetNode(parentHandles[parentIdx]);
				DSL_nodeDefinition *parentDef = parentNode->Definition();
				DSL_Dmatrix &parentCPT = *parentDef->GetMatrix();
				const DSL_idArray &parentOutcomes = *parentDef->GetOutcomesNames();
				const int parentNumberOfOutcomes = parentDef->GetNumberOfOutcomes();
				string parentNodeID = parentNode->GetId();
