In tutorial 6: Learning a Dynamic Network with EM we use a data set as follows:
A A_0 A_1 B B_0 B_1 C C_0 C_1
I understand that i_0 and i_1 represent variable i at time slice 0 and 1, respectively.
Why do we have the other columns, 'A', 'B', and 'C', that are not attached to particular time slices? What do they represent?
I noticed that the provided code asserts that the given node id can be found (so does require them). dsMap, however, is only updated on the "slice" columns 'A_0', 'A_1', 'B_0', 'B_1', 'C_0', and 'C_1'.
Thank you!
Smilearn - tutorial 6 - why do we need A,B,C?
Re: Smilearn - tutorial 6 - why do we need A,B,C?
The tutorial is quite old. The preferred conventions for column names is to use node id only for 0th slice and node id + underscore + slice number for subsequent slices. GeNIe's UI for EM learning uses this convention for automatic matching, including the slices > 0. However, SMILearn's DSL_dataset::MatchNetwork will only match 0th slice based on identical node ids and column names (hence A instead of A_0).
