using rSMILE
davidfdavis
using rSMILE
Post by davidfdavis »
I've been away from smile for awhile and now want to use the rSMILE package, I have previously been using SMILE.NET and SMILE.COM successfully. I have been following the directions in the Wrappers manual (I think) and tried to load rSMILE with: install.packages("C:\\Users\\~~\\rSMILE_1.6.0\\rSMILE\\libs\\x64\\rSMILE.dll") which yields "package ‘C:\Users\~~\rSMILE_1.6.0\rSMILE\libs\x64\rSMILE.dll’ is not available for this version of R" I'm using R4.0.3 in rStudio 1.3.1093 Note that I did try to go back to R3.4, but that didn't work either.
Re: using rSMILE
Post by piotr [BayesFusion] »
You don't need to unpack the .zip archive. Besides, if you have files locally, you need to set the repo parameter to NULL and specify the library type - win.library.
The full command for installation will look like this:
install.packages("path_to_zip_archive", repos = NULL, type = "win.binary")
Also, if you are using RStudio, you can use an alternative installation method by specifying the path to the library in the installer next to the list of installed packages.
davidfdavis
Re: using rSMILE
Apparent success! Many thanks,
