Hi Administrator
I got a problem with the self-defined probability distribution function - CustomPDF in using the equation node.
Please see attached two sample nodes, one defined as a uniform distribution, the other a quite evenly spaced uni-model distribution. However the displayed pattern is very confusing - the first node not only displays a non-uniform distribution but also show a large empty space in the middle. The 2nd node also shows a large empty space in the middle which is not featured in the original data to define the PDF.
Could you help with that?
Charlie
User-defined PDF function
- CustomPDF.xdsl
- (1.24 KiB) Downloaded 436 times
Re: User-defined PDF function
The CustomPDF function requires the x coordinates (the first half of function arguments) to be in increasing order. Your equations have descreasing x ordering.
BTW, please check your private message inbox on this forum.
Thank you Shooltz.
Charles
Charles
