GeNIe and high resolution
adam
Contact:
Post by adam »
Dear GeNIe developer,
I've just installed GeNIe on a new laptop with high resolution screen (3840x2160) and GeNIe toolbars and canvas space) are extremely small (making them virtually unusable). Basically, whole layout is rather a mess. I wonder if it would be possible to fix in the near future, as I expect more and more users will be using this kind of resolution in the future.
I'm attaching a screenshot that visualises the problem.
Best regards,
Adam
Re: GeNIe and high resolution
It didn't attach :)
adam
Contact:
Post by adam »
Sorry this time it should work:
I prepared the second screenshot, that should let you appreciate the scale of the problem. One of quick workarounds would be to allow for zoom greater that 200%, because even 200% is a bit limiting. Keep in mind that the picture is actually re-scaled.
Does the trick described in the video below help?
How to Fix App Scaling Surface Pro 4 + Other High DPI Displays
https://www.youtube.com/watch?v=UijLRNQ6N7Q
adam
Contact:
Post by adam »
Tomek,
You are genius (it's not like it's the first time I think so...).
It worked flawlessly. Thanks!
Adam
